Turbo Trans Am Forum
Go Back   Turbo Trans Am Forum > Turbo Trans Am Modifications > Tech Tips & Tech Support
ALL NEW REGISTRY Register FAQ Members List Calendar vBGarage Search Today's Posts Mark Forums Read
Tech Tips & Tech Support Need Help? Get it Here.Share Your Knowledge and Give a hand with other TTA Owners!
Reply
Thread Tools Display Modes
  #1
Old 07-27-2010
nhra-trans-am's Avatar
nhra-trans-am nhra-trans-am is offline
Junior Member
New User
nhra-trans-am is on a distinguished road
Car failed CA smog...Need some help
I recently purchased an 89 TTA and I am trying to get it to pass CA smog. It failed due to the high NO level of the smog test.
The car was idleing a bit rough so I changed the spark plugs, pcv valve, fuel filter and serviced the fuel injection. However the idle is still rough. I was thinking that maybe the TPS sensor was to blame. Need some help figuring out what the problem is. TIA
__________________
1989 Turbo Trans Am
T-Tops / Leather
  #2
Old 07-28-2010
Junior Member
New User
Re: Car failed CA smog...Need some help
Here are the smog readings
15mph HC max 80 ave 33 meas 34
25mph HC max 62 ave 24 meas 28
15mph CO max .52 ave .08 meas .02
25mph CO max .42 ave .06 meas .03
15mph NO max 549 ave 165 meas 544
25mph NO max 507 ave 142 meas 1300
__________________
1989 Turbo Trans Am
T-Tops / Leather
  #3
Old 07-28-2010
TURBO1's Avatar
TURBO1 TURBO1 is offline
Super Cool Member
PowerUser
TURBO1 is on a distinguished road
[QUOTE= It failed due to the high CO level of the smog test.
Maybe I'm reading it wrong, but according to your readings, it looks like you failed NOx on the high speed test, and about boarder line on the low speed test.
The CO's look like there in spec, I'm I reading that right? Are you using premium fuel? Does you car have the stock chip? High NOx can be caused by the following:
High Heat, Lean Mixtures, Advanced timing, EGR not working properly, cooling system problems, Excessive carbon build up in the combustion chamber, Hot spots in the combustion chamber & usually the #1 culprit, a defective Catalytic converter. Hope that helps
__________________
TTA 20th Anniversary: Power in the hands of few
Car show cruisers:
1989 TTA, #591, T-Top, Leather,
1981 DeLorean, DMC-12, 5-Speed
Big Boy Toys:
1997 Yamaha Vmax, Stage-1, KerKer Slip-ons
2002 Yamaha Raptor 660R, Stage-2, DMC Exhaust
Daily Drivers:
2004 Tundra, Double Cab TRD
2007 Camry SE, (Wife's car)
  #4
Old 07-28-2010
Junior Member
New User
That is correct, I went ahead and edited it. It had a high NO level. I am using premium 91 fuel.
I just bought the car, but as far as I know it is bone stock, including the chip. It appears to have a new cat on it though.
__________________
1989 Turbo Trans Am
T-Tops / Leather
  #5
Old 07-28-2010
TURBO1's Avatar
Super Cool Member
PowerUser
Congratulations on getting your TTA!!! I would double check your chip, just to make sure its stock, its easy to do. When I bought mine, the owner said mine was stock too. Come too find out (couple months later) it had a ATR Pitbull race chip, go figure!
I would also check your fuel pressure, as running too lean can raise engine temp & cause major damage. Make sure your newer catalytic converter & EGR are in proper working order also.
__________________
Car show cruisers:
Big Boy Toys:
Daily Drivers:
  #6
Old 07-29-2010
Junior Member
New User
How would I check the chip?
__________________
1989 Turbo Trans Am
T-Tops / Leather
  #7
Old 07-29-2010
SouthBaySurfer's Avatar
SouthBaySurfer SouthBaySurfer is offline
Senior Member
Mild User
SouthBaySurfer is an unknown quantity at this point
I highly recommend Turbo Tweak's emission chip. It cleaned up #14's emissions by a wide margin...and it's cheap; about $20.
__________________
Jim #14 Festival Car 18k miles
#916 cloth/t-tops 52k miles-sold
  #8
Old 07-29-2010
TURBO1's Avatar
Super Cool Member
PowerUser
Quote:
The computer is under the RF (passenger front) dash area, you'll have to
remove a couple trim items (very easy) & it pulls down. There will be a small rectangle looking access cover, remove that & the chip is inside. I'm not sure what the stock chip says on it, since mine did have one, might be a part number (mine said ATR pitbull) right on the chip.(if someone else can chim in here to confirm what a stock chip looks like or whats on it, that would be super, pictures are great)
Eric's Turbo Tweek chips are great, thats what I switched too also, but I would still confirm what you have as a starting point.
__________________
Car show cruisers:
Big Boy Toys:
Daily Drivers:
  #9
Old 07-29-2010
TTA984's Avatar
TTA984 TTA984 is offline
User
TTA984 is on a distinguished road
Here is the chip that came in my tta, I just put turbo tweak classic chip in. What a difference, it idles better, it runs better, it runs cooler and turbo spools up faster. What a great chip.Attachment 1925
  #10
Old 07-29-2010
Junior Member
New User
Quote:
Thanks for the help. I will look into it today.
__________________
1989 Turbo Trans Am
T-Tops / Leather
  #11
Old 4 Weeks Ago
bossbird ta's Avatar
bossbird ta bossbird ta is offline
User
bossbird ta is an unknown quantity at this point
Thumbs down Re: Car failed CA smog...Need some help
nice to see that i'm not the only one who has Smog troubles with the great state of california....thanks Arnie!
  #12
Old 4 Weeks Ago
mr.turbota's Avatar
mr.turbota mr.turbota is offline
Super Moderator
SuperUser
mr.turbota is on a distinguished road
That's one reason I left!
No smog checks here.
George
__________________
George
Go for the top of the food chain, and run wild!
1989 20th Anniv. Turbo Trans Am #231 (autographed by Emerson Fittapaldi in gold, winner of the 1989 Indy 500, on my dash panel glove pocket)
Featured in:
Books:
Pontiac Firebird Trans Am 1969-1999 Photo Album
Pontiac Firebird 1967-2000 Photo History
Firebird Trans Am by David Newhardt
Magazines:
Smoke Signals Sept 1993
Car Craft March 2000
  #13
Old 2 Weeks Ago
Junior Member
New User
UPDATE
I replaced the MAF as suggested by a member here and the car is running a lot smoother. No more hesitation or stalling.
I do have one more problem. The car also failed the EVAP test. I replaced the gas cap, but I think there is more to the problem since they hooked up a machine to the gas filler that eliminated the cap during the test. Anywhere specific I should be looking? Thanks.
__________________
1989 Turbo Trans Am
T-Tops / Leather
  #14
Old 2 Weeks Ago
TURBO1's Avatar
Super Cool Member
PowerUser
I didn't think these cars had that capability being 1989 OBD1. WOW is California strict. Anywho, There should be an evap charcoal canister & a purge valve to control the amount of fuel vapor. If the purge valve is stuck open or if the canister is cracked, it will fail the test, being 1989 it should be a VERY basic system.
I really thought, they only checked evap test on 1996 OBD2 & up were its monitored by the ecm... I learn something new everyday...
__________________
Car show cruisers:
Big Boy Toys:
Daily Drivers:
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2000 - 2010 TurboTransAm.com
