the wonder bar
adam levy
well i ordered it and could not get it on , am i missing the boat , the intercooler was way in the way any body help lol please let me know if anyone ealse had the same problem ,,,, thanks
Some get it to fit by flipping it around, seen some pictures of it but must be tite. I had a custom one made for mine with longer brackets to bend down slightly so fits inbetween the IC scoop and bottom of the cooler fans very well.
See pictures of mine installed; fits and works very well.
We removed the original plates you find under the swaybar brackets and used them as templates (and same thickness) for the plates/brackets on the new wonderbar .... then installed without the OEM plates not to alter the installed height of the swaybar.
ends of the seamless tubing we used were capped then the whole thing powdercoated.
Came out really well and looks like a factory piece.
And before I installed it ...
yep - flip it over and it will fit...
Reason I did mine like I did was that I don't have enough space where you run that standard wonderbar to get it to fit without squasing the lower fan brackets (where they bolt in place) ... and putting strain on the IC scoop/duct. But looks like you might have more clearence than I got on mine.
