Attached is a PDF were I included the GM notification to the dealers about the missing TURBO fender emblems along with what PAS sent to the dealers toget it installed.
These are pieces I've collected over the years on the internet so if any of you do have the original documents and could scan them I can do a new updated PDF in better quality.
Also the template to use if you're going to install or re-install your TURBO emblems is attached in JPG format so you can print it out ... should print in the right scale/size
