If you own a TTA,they won't fit.
You have a 1 LE braking system.12" FRONT & 11.7" REAR.
Why not just rebuild them?
You could also go with Baer or another good brake manufacturer,but they are "not" cheap!!
I believe the rears are the same as regular 3rd gens (the pads are the same if I remember right) and the front calipers look almost identical to my friends 89 Corvette, so those might be a match too.
the ones from autozone are correct ,part #c365 for one the fronts. although i dont think ther are aluminum as they list the weight at 7.1 lbs seems heavy. i know others have used them, someone from one of the old mail lists had them. i have found pbr replacements at $250 each for a loaded caliper. i figure IF the autozone ones are aluminum at $80 each it beats rebuilding them myself.
the rear calipers are diffrent from regular 3rd gens. thankfully the front is only the problem as the cheapest rear pbr calipers i found were over $300!
