TTAGUY
1 - What is the size of the stock muffler? Length from one end to the other of the pipe ends, not just the muffler itself? Also the width, and the height?
2 - what rear gear oil should I use? Rear has a leak so might as well change the gasket and oil, and how much do I need? Stock rear, and from what I know 373 gears, I will be changing those when the car is on the road and I make sure everything is operating correctly.
Thanks for the help in advanced,
Marcel
Marcel
