HELP lost my boost
jarredsoon
OK.
So I have a stock tta and decided to put a K & N airfilter on it, so I got one that fit onto the elbow and into the corner of the fender. I put it on.
So then I decided to put a breather on the valve cover on the drivers side. I removed the pipe and put a breather on the valve cover and took the pipe right off. the other end of the pipe goes into the inlet bell of the turbo so I put a cover on that.
NOw I can't get more than 5 lbs boost when WOT. WHat is going on. WHat did I do???
SO I take the breather off and re-attach the crank case vent pipe and hook it up between the valve cover and the turbo inlet bell, still no more than 5lbs boost.
What do you guys think?
Thanks.
Is the wastegate rod attached to the puck with the C clip? Check all the hoses on the Y connector.
Well I checked the "Y" tubes and they all are ok. No cracks or tears, the car makes a very high piched sound when I let off the gas when test driving, not the usual sound it makes releasing the air. Is there a way to adjust the stock waste gate???
I am still confused. I did not do any real change to the car??? and I can't find anything wrong (although my skills are limited.) It seems to make power up to about 5lbs and the car can no longer accelerate and/or create more boost and boost just stays at 5.
Does it buck or sputter? Check all the hose clamps on the intercooler,up pipe, maf pipe. Maf sensor pluggen in? The rod from wastegate is connected?
OK the bottom bottom hose clamp on the intercooler was OFF!!!! I did not notice it, I checked what seems to be everything else. Thank you CHris. :) I am good now.
