Jim Dunn Intercooler install
There is a hole in the shroud forthe sway bar. I believe you have to install the intercooler with the metal shroud off, then place the shroud onto ic by placing it infront of the sway bar then onto the ic and screw it in place. I am not sure though bc I don't have the front sway bar on my car.
Be sure to turn your boost down mine went up 4psi just by installing this ic. You sure don't wanna overboost and have to change headgaskets.
We got it installed. Original owner had sides welded shut to run w/o swaybar I think.. Thanks for the info.:thumbup:
