Map Sensor
duarosca
Does anyone have pictures of the map sensor plugged in with the adaptor harness showing the colors of the wires.
It would help a bunch to verify if the correct.
These might also help ... adapter was used as the turbo gauge would show the wrong PSI (Denso mistake I think) ... one of the wires in there have a resistor soldered into it to compensate making sure the gauge shows (as close as possible) the accurate PSI ...
You guys are awesome, really appreciate it guys.
Sent from my SAMSUNG-SM-N910A using Tapatalk
I had no idea that was an adapter. Thought it was just a connector. Learned something new today:)
What I'm looking for is the harness wire colors from the car before the adaptor
Ok now I am confusedo_O. I just got home from work and went to take a pic for you and realized two of my cars don't have this adapter. Was this a recall thing or were they supposed to have this from the factory? I even have an extra harness and it doesn't have this adapter either.
I did take some pics for you and I am confident of the wiring colors and their order.
If you look at the connectors you will see A B C embossed on them.
The wires coming from the harness are A=black B=green C=gray
The wires on the adapter are A=gray B=green C=black
So its totally reversedo_O
That's wierd, but thanks for taking the time and helping me out with this, my car had some fire damage years ago and its been running ok since I fixed it, I had to cut some harnesses from the cars at the junkyard to make it run.
Do you have a pic of the tps wires.
This is my work horse, all day every day, to work and back, driving around town, taking my boys to there baseball games.
Car needs to run good.
Right on man, thanks again. Really appreciate the help.
And you may want to check those fuel line by the alternator just for piece of mind, there is a fastener that holds the lines in place right, well the fire damage came from there, it wore a pin size hole on the return line that sprayed onto the alternator.
