Made up a set of plug wires for my TTA after one of the OEM’s I had on failed (terminal @ spark plug were loose and made no contact) and being 20+ years old I thought I should be driving around with some proper new wires and save the others for shows and photo shoots only.
Picked up a set of MSD Street-Fire Wire’s (Street-Fire Wire Set Multi-Angl plug, HEI, Univ - 5550
) that I could cut to length. Kit comes complete with everything; even a handy tool (that actually works very well) to help cut the correct length and use to crimp the terminals is included.
So cut them to the correct OEM length using a NOS set of wires then numbered them accordingly, routed them identical to the OEM wires with all the bells and whistles as from the factory and looks great.
Plug ends you can bend to anything between 90 and 180 degrees so perfect for anyone like me running a 3” downpipe …. 8mm wires and all made in the USA!
Took some photos for you all … and these are cheap and you can easily build a set in an hour.
Perfect fit, only thing is the OEM metal heat shields won’t work but they should hold up otherwise a heat shield sock can be used and I might just do that on no 2 and 4 ….
