Hi, My car has had no start/crank when problem for a few years now. I would just
replaced the starter and car would be back to normal, but the starter life was about 2 years max before it got damaged again. The south texas heat also did not help much. I recently replaced it again cuz it was getting worse, but the problems is still present with new starter and heat shield. After some hours of cooling down or a jump start..my TTA is back online as normal. Do you think its the old beaten starter/battery wires. What other things can I look at? Do I need to move the small starter wire "R" or "S" around? Thanks for your time.
Roy
Roy
