Ok here we go again. Still working on the no start problem once the car gets hot. When the car cranks the noid light for the injectors is very weak. If it does finaly hit off it will get stronger. We do have one issue that we found of only 5.1 volts from the igntion modular to the cam sensor which the book indicates 6-9 volts. Not sure if that is messing up the computer on hot start up. If the car is shot with starting fluid it will start every time. No codes are showing up. Has anyone ran into this problem before? We have replaced the coolant sensor, MAF, cam sensor and crank sensor. Next thing we can do is shot and put it to rest. And yes the car has 1600 miles on it. Any help would be great.
Jeff
Jeff
