Part #'s for Spark plug wires & oil pan bolt
TURBOGTA
Jan
would you happen to have the part# for
Spark Plug wires
metal boot protectors
oil pan bolt
bracket you need for fuel line
oil pan bolts and studs:
#25520079 (x3) these are for the front cover section of the pan
#25520241 (x3) studs for the transmission cooler line clips (2 on the driver side) and the starter motor wire harness clip (1 on the passenger side)
#25535721 (x14)
plug wire kit - 12073997 (Delco 616N) (note early on they had the 20th Anni... printing on them; later style same part numbers don't)
metal boot protector (spark plug heat shield) (the old style we have on the TTA) is #12045580 (AC Delco 8005) ... the new style that replaced "ours" is 15336959 (AC Delco 8006)
bracket I need - #10136857
