The lower radiator airdam/deflector as you know been discontinued, however still places on-line where you can get them some more expensive than others, and I just found the instructions for mine so scanned it and also scanned the bag with fasteners as it got the part numbers on it (see attached 2 page PDF).
Note that for the TTA the center section have a cutout for the intercooler scoop so if you do replace it make sure to keep your original one to use as a template to cut the new one accordingly. I used a small cut wheel on my dremel when I did mine years ago.
Part number for the complete kit (center piece, left and right pieces and the bolt/nut kit is 12395557, the centerpiece is 10118484 and the right/left pieces are 10118482/10118483.
Hope this will be of use to some of you out there.
