amitch
Just looking for everyones thoughts ideas experiences etc. Im in the market for an enclosed trailer. I was planning on purchasing a 24' 10k gvwr haulmark trailer, nothing special just plywood interior a base model for a little under $7,000.00. However I recently came across a used 48ft gooseneck racing trailer. For under 9k. Way more trailer and options than what I was shopping for it has 3 - 7000 lb axels aluminum cabinets, 2- winches, one in front and one on back door. It also has an a/c unit, furnace, diamond plate floors and half walls. As well as an air compressor, 40 gal water tank, and 30 gal hot water heater. The rear laoding door is polished Aluminum with LED lighting and also has an awaning attached however the canvass material on awning needs to be replace. More than what i need but at that price it looks like a bargain. Its about 1.5 hours away from me an I may go check it out this week.
What are you guys throughts on enclosed trailers? Especially what is mentioned above. The cheaper price the better for me.
