I'm trying to get my alchy to run with no knock.
The things i have done to the car are
pretty much stock stuff with Alchy.
FPR, Hot Wire, Scanmaster, K&N, TT chip for alchy.
Idle scan numbers are okay (BLMS, INT's, IAC). BLM's and INTs solid 128 after being warmed up. When cruising BLM's drop to around 122.
Fuel pressure reading 41psi with hose off.
Gauges i have are wideband, fuel pressure, and boost gauge.
I'm seeing around 2-4 degrees of knock at WOT from a 3rd gear roll (should the roll be done in overdrive or drive?). Doesn't seem to matter right now but may help with the troubleshooting.
Right now i have the stock wastegate in but i do have an adjustable one. I've just been trying to get it running at stock boost before upping the boost. For this reason i'm pretty sure i'm running rich up top (wideband reading low 10's).
Is it better to try and pull fuel up top with the stock wastegate in or should i just throw in the adjustable wastegate and up the boost? I'm not really looking to push it power wise right now. Just want it to be tuned safely.
I'm kind of hesitant to pull fuel as i'm getting some knock already. But for all i know it could be somekind of rich fuel knock.
