TurboJoe89TTA
TurboJoe
I installed a Thrasher chip. When I give it 1/2 to 3/4 throttle it seems to accellerate faster than WOT throttle. Boost seems to go off at 1/2 throttle. Sending the factory guage over 20 PSI. I know these guages are not all that accurate but... Plus the idle acts kind of funny. Smooth, then sounds like it is going to stall, then smooth again. I read the Thrasher instructions and it said this could happen if the AIC (air idle control was not set properly. My gas is 3 years old too! I ran it down to 1/6 of a tank then fueled with 2 gallons of Mobil 93 octane. I figured I would mix a little higher octance then refill at the empty mark.
I do have a direct scan 1.5 version but I do not know how to use it. I do not have a scanmaster. Help.
