Wheel Question?
TTA984
I read somewhere that if the rear GTA style wheels are mounted on the front they will rub. Are the rear ones slightly different?
If you rotate your tires could there be a problem?:rockon:
Yes that is correct, you can't rotate front to back, back to front.
The reason I ask this is because around a year ago I had new tires put on. I had the correct size BFG sports installed. The front tires seem to rub somewhat what I am turning sharply while parking. I just wonder if they installed the rear wheels on the front to cause this.
They do rub on the inner fender plastic thing up front .. you see it on all GTA's etc as well with the 16" 245 tires. Not much but just a slight wear will show.
On the back side of the wheels they area marked "Front" & "Rear". If your tires are non-directional you can rotate side to side. If the tires are directional, then they will be stuck in there current location, unless you dismount & remount the tires off the wheels witch can be a pain.
