18psi off boost on 92 octane
You want to free up the flow and let the car breath less restriction stock dp sucks. 3inch frees it up adds hp car sounds amazing.
didn't say it did not add hp ... u can buy a roller cam cheaper than a terry Houston dp an make more power ... ive been around these cars a min ... I have a 8k motor in my car not counting inj front mount dual intanke pumps 9 inch rear end dennys drive shaft a pts full billet 2004r alky kit trans brake an the list goes on
Well I'm commenting on his original post he wants to go a little faster. Roller cam would b over kill for what he wants. And u can get 3in dp for $300 no need for Terry Houston and also I would tell him get a power logger
ummm I wouldn sell u my stock dp for 300 u can buy a boot leg knock of Chinese dp for sure ... se how it works out for you
what does your car run ? with what mods ... im pretty sure I got stock suv that will run same #'s
Woah there guy..
TTA MODS: tuned @25psi
60#fuel injectors/chip turbotweak
Alky Alcohol/injection kit m1
160degree thermostat
Power logger scan tool/tuner
3in chrome up pipe
RJC Powerplate and Pelenium
Comp Cams 100# valve springs
Te49 turbotonics turbo
Walbro High pressure fuel pump
Fuel pump Hotwire kit/adjustable fuel pressure regulator
RJC Adjustable boost controller
Rebuilt 200r4 brf trans heavy duty internals 2400 stall
Fresh head gaskets/milled heads
Dual fan bypass
Toyo proxes tq Drag radials
3 inch Down Pipe dumped
Big neck intercooler
Valve cover breathers
3in chrome maf kn cold air intake
Ur SUV will run 11s?
yes sir it will with a baby seat an stroller in the back ! rear DVD side curtain airbags sunroof leather an can haul my tta's or gn ... do u have any slips to prove your times or is it a guestimate ... because everyone has a 10 sec ride on the interweb. btw I bought it new
that's why I was asking how u know its in the 11's ? tbss 13 sec suv ... stock it ran 13,55 now add mods like u ... yes its deep in the 11's
I seen where u posted new head gaskets did u use cometics ? an arp studs ? 30 psi was on the spikes
