you mean the 35 doesn't have a anti-drain back valve? Just did a quick search and answered my question. The 35 does not have a anti-drain back valve. Why would they make the filter without a anti-drain back valve?before i went to the reunion i did an oil change and found delco went back to using the original PF 1218. the newer version now has anti drain-back and is a little shorter for better fit. Aiameter remains the same
The 1218 is still longer then the Wix. It is about 4.5 inches long. The Wix is 3.5 inches long. How is the clearance? The last time I had an AC filter on the car, it wound up with a hole in it.
