Cool, thats what I was looking at also, I've attached some photos, if coming off the intake goes to the map, then mine might be hooked up wrong, take a look at the pictures & let me know if its correct. I did jump the map sensor black & green wires (key on engine off) & the boost gauge jumped to full 20 psi, so I know the gauge works. Thanks for any helpI guess "controls it" is accurate enough.
Try this for vacuum routing for the engine compartment. The line labeled HVAC goes through the firewall and is parsed out to run defrost,floor heat flappers and anything mechanical that needs moved around in the dash related to heating and AC.
No worries on that part, its staying in my garage, till it gets sorted out.Dude...and I don't use the word dude lightly...you got some 'effed up vacuum routing,open vacuum souce.
Don't push that car hard till you get those fixed first....and your MAP isn't seeing vacuum the way it's hooked up now. And that's why your boost gauge doesn't work.
I'll get back with you later.
Cool, thats what I was looking at also, I've attached some photos, if coming off the intake goes to the map, then mine might be hooked up wrong, take a look at the pictures & let me know if its correct. I did jump the map sensor black & green wires (key on engine off) & the boost gauge jumped to full 20 psi, so I know the gauge works. Thanks for any helplease:[/quote
Well, I found some info & they way its routed on my car is wrong. The MAP hose goes the the intake runner as per the diagram. The wastegate solenoid port should be open w/a foam filter? Does this sound right? At the wastegate solenoid does the filter go on top or the lower port? My "Y" connector hoses from the turbo/wastgate go to the lower port on the solenoid, is this right? So the only thing I need to find is were the small black vac hose coming out of the harness connects too.
