Ok, so on the way home it was shutting off again. Luckily I bought a fuel pressure gauge while I was out in Ohio and made sure the pressure was set. The first time it shut of, it would not restart. All the gauges were reading normal until it shut off. It acted like I was running out of gas, the wideband and scanmaster started reading lean. I hooked up the fuel pressure gauge, turned the key on, and no pressure. I couldn't here the pump kick on, but I was right beside the highway and traffic was heavy, so it was hard to here anything anyways. I cycle the key off and on a few times while also purging the fuel rail using the drain valve on the FP gauge. Finally got gas through the drain valve along with a lot of air. After all the air was purged out, fuel pressure shot back up to normal, and I could drive for a few miles till it lost pressure again. Also noticed once while it was running with the gauge still attached to the fuel rail I started to lose pressure and it was going to shut off, I hit the purge valve on the gauge, got a little air out then just gas and it started running fine again. Then we stopped for about 30-45 minutes got gas, let everything cool down, and I drove the rest of the way home, about 140miles with no problems. Any insight to what could cause this is greatly appreciated.
