Cooper Gaskets For Headers
duarosca
Always had a problem with the passenger side header developing a leak since the catalytic converter plugged, I've tried just about everything except a new flange, or header since they cost so much to custom make...I really hope this will solve my problems with my blm being low.
Oscar
Whao, I just checked it on fullthrottle page and I have ordered many parts from them in the past, if this doesn't work I'll that a try.
Oscar
I have the part # for the TTA reflex header gaskets , not home now it would take me a couple of days to get. Or check with full throttle they would know!
Have you checked the header on a certified flat surface????? I spoke with Bison and he said unless your header isn't severely warped use copper rtv. I found a local metal fab shop that had a granite flat block. Checked for flatness and was pretty happy. I used copper rtv and no leaks...
I took it to a machine shop a long time ago and it was good but after placing it back on using rtv it was good for so miles until I got on it, it would do it again, that when I took the cat out and seen that it was plugged, actually it melted from the center, so I just broke the center out and never fixed the leak.
Oscar
I hate to do all that work taking it off just put some rtv and have the leak develop again that's when I just decided to used the copper gaskets as a last resort.
Oscar
And you can tell when it has a leak because it sounds like a v8 and people think you have a v8 when you start it, but we that have had this cars since early adulthood know that it's a distinctive sound like a mechanical robotic yet not sure how to explain it and when it has a stainless steel from the headers to the back even more.
Oscar
