couple questions
Fast231
Turbo Luvr
Hi All, I decided to buy a module that will allow me to open my cut out froma remote(key fab) and i am going to hide the box under the hood. Anyone know where i can find ingnition power under the hood?
Does the TTA have a grommet under the power master where a clutch pedel would go through into the inside of the car? Is this the best way to route wires (Wb/boost/fuel pressure) into the car?
Thanks!
ttarider
I am pretty sure you need to drill a hole for your boost line and fuel pressure wires. The gauges usually come with a gromet to put into the hole in the firewall that you cut. If not I think I have one you can have.
There is a gromet in the firewall that other wires run through on the drivers side, you can run the boost gauge and stuff through that same one, you don't need to drill new holes.
Thanks guy's...I have not looked yet--but the car should have a grommet where a clutch pedal would be mounted on the car..... No?
There is a unused grommet in that area if it's for the clutch pedal or not I'm not sure but if you look down there you will see it ... I punched a hole in that one for my boost gauge vacuum line as well as a hole for the fan over ride swich I have on mine.
