Thank you for the info. I'll post my results.Also, if replacing the circuit breaker doesn't work, try replacing the switch in the dash. Just make sure it's a good replacement brand like borg-warner. I had problems with my headlights not going up and down ,, and traced the whole electrical system out and found out it was the headlight switch. I replaced it and worked great. Electrical problems suck ,, so I would try the easy fix Solutions first. Good luck....
