Does anyone have their original battery?
andre#4
I am looking for pictures of the original battery. I am sure some of you crazies have saved your battery. Does anyone have some pictures of it? I would like to work on reproducing or rebuilding one of them. I have the battery from my 91, but the part numbers, catalog numbers, and decal designs sometimes change from year to year.
Thanks for any help on this.
I have the battery from my 89 formula 350. Its still in the car!
Ill try and get a better picture of the top later..
That is perfect!
Does the top come off? I would pay you to take that top, put it on a flatbed scanner, and send me the scans. I need to recreate the decal for the top. I was going to suggest someone take their scanner and put it upside down on top of their battery, but this is even better. I really like that setup you have there. I don't suppose you would be willing to part with that case for an inordinate sum of money, would you?:yes:
(We should have a smiley who is handing money over to another smiley, who is sitting in a chair with a cigar in his mouth, laughing as he takes the money.)
I have been searching for ways to recreate the original battery, or at least the looks of it. I noticed that most batteries today have handles, which is not good for this project. They also have black cases, which is also wrong. The original is a white translucent case with black maintenance free top. No caps. I noticed that interstate batteries have white translucent cases and no handle. that is a good start. All we would need is a topper for those batteries and we would be doing pretty well. The topper is a plastic piece that looks like the top of the original battery that is generally put on top of modern batteries. I included a photo of one of the interstate batteries. You will notice it says interstate on the translucent case, in huge letters. This will not be a problem because this is on the side of the case that is invisible when the battery is mounted in the car. The other 3 sides of the battery are unmarked by branding. Having a topper on this battery could be done in such a way as to totally hide the fact that it is a topper. It could be glued to the battery. And since there are no terminals on top, and the original battery did not have removable caps, there would be no way to see that it was even a topper. It would look totally correct. Now, I just have to figure out how to get the topper. Or make it. Looking at the above post, it seems that if you could find old batteries, you could remove the tops and use them. It could be refinished if need be. New decals could be used. Sears has a diehard (die easy?) battery with no caps, and maybe the top of that diehard battery is the same design as the old delco top. I will have to check on that. Anyway, if someone can get me a good scan of the decal I will be reproducing them somehow or another.
I can't imagine they will make repro batteries for us. Not any time soon anyway.
Nope not 4 sale! lol Ill try and get a good pic of it 4 ya (No scanner). The yellow is faded fairly bad but its there..
As far as Ive seen the napa/ac delco case is the most correct top plastic molding but the color of the lower part is wrong.
These arent the best pix of the batteries buuut..
cheaper napa(not the 1 I was looking for)
More $$ delco
here is mine. (edit: I posted the wrong one, this one came out of a 5k mile 92 GTA years ago)
Yellow is faded where it says sheild eyes/ do not tip.
decal is 3"plus x 6" 7/8
That delco looks great but it is a group 78 size which I believe won't fit. Tell me if i am wrong here. Can you fit the 78 series battery in the battery tray of our car? Our cars usually take the 75 series battery which is 9" wide as opposed to the 78 series which is about 10 or 10.5". that 78 series delco case looks so good. Besides the black color it looks like even the side panels might have a similar design. If you have a 78 series delco there, maybe you can check on that. (the side panel design). You can see on your original battery the side panels have a design with a bunch of squares. Does the 78 series delco have that?
Yeah those arent correct size batteries just what I could find on the net real quick. I'll get the batt measurements you asked 4 today maybe. car is on the lift. Motor out again!
Sears and k mart sell diehard batteries and they have a new design with a flat top. Like the original delco freedom top except no delco eye, but at least a maintenance free flat top without caps. That is hard to find on the bci group # 75 battery.
With that diehard batt, you could put a repro delco freedom sticker on it and it would look very good. (no delco eye and not white sides, but what the hell)
If I had lots of money I would get the interstate batt, with the white case, then get a diehard batt with the flat top. then take the top off the diehard and use it as a topper for the interstate and put a repro sticker on it.
But it would still be wrong and that would be expensive.
If I could just find a used batt from a corvette. or another gm used batt with the delco eye.
I would pay $80 to anyone who has an old useless delco batt for me. It has to be group 75 (side terminal) with delco eye. If you have the white sides, like formula 350 pictures, I will pay more.
