Leaking issues..This depends on how well the machining is.
Add 3/4'' to crossover
Might have to clearance the K member
Some people have cracked their block from the thin webbing up front.
Im putting out a good 600hp with mine and just swapped to ported street eliminator heads. Should be around 700+
I have an RJC girdle with steel mains and forged internals.
...looking at their cars in the garage... that's a good way to put it. To obtain the necessary frame clearance with a girdle, some have instead reworked the oil pan sheet metal. I briefly considered having that done, but I didn't know a local sheet metal fabricator that could do it for me. So though most likely not nearly as robust as a girdle, I did what I could and had my machinist install steel caps in positions 2 and 3.
