TTA579
South Bay TTA "Barn" Find
TTA579 failed for the second time.
Emissions were actually worse than the first time I had it tested. The previous numbers were 97/69.
I have some theories about what is wrong.
#1, bad gas. While the car has been filled since the tank that ate through the fuel pump coupler, it may need another tank or two before all the denatured crap is out.
#2, damaged cat. Simo provided me with an emissions history of the car indicating that it had failed in the past. A quick inspection of the catalytic converter shows that it has been replaced (welded in
). Whatever caused the catalytic converter to fail in the past may have happened again. I'm thinking particularly that the previous owner managed to damage it somehow driving around LA with such a low car. A slight rattling noise at around 1000 rpms on startup supports this theory.
#3, tune up. I plan on having the car serviced today with new fluids, and I have a new set of spark plugs on hand.
1 and 3 are easy to fix. Finding a trustworthy exhaust shop will not be fun.
