89tta636
Uggghh!
-So cruising with the TTA and stopped by a friend's house. When I went to leave, the car would crank like heck but not start.
-Thought I started to smell some fuel so left the car sit for a few minutes.
-Tried to start it again and it would almost sound like it wanted to fire over.
-When I would turn the key to the run position, the fuel pump would turn on but then after a few seconds, a buzzing sound from the fuel rails and injectors happened and they were vibrating too. Turned the key off and back on again and it did not do it.
-Eventually got the car running but wouldn't run without keeping foot on the pedal a bit. Then it would idle ok.
-Got the car home very carefully, left car idle and it was fine. Turned it off and it started right back up.
-Only computer code was an old EGR Valve code.
-So this problem happens intermittently, which makes troubleshooting harder.
-Anyone experience this and have any ideas on what it could be?
-I will disconnect the battery to reset the computer and check all the grounds to the engine too.
-Car is all stock and original, no chip or anything.
-Has new plugs and wires last season with about 2,000 miles on them.
Thanks for any thoughts.
