Here are some pics of the fuel tank and what is involved in removing it.
This is a perfect picture of the exhaust, that needs to be removed, and the heat shield above it that needs to be removed.
Here is a picture of where the exhaust needs to be removed on back...
I loosened the top panhard bar by these three bolts on the drivers side. It allowed the rear to drop enough to slide the tank out.
One of the hotwire relays.
And another relay from the Racetronix kit.
I highly reccommned replacing the rubber fuel lines. As the cars are almost 20 years old it is cheap insurance. They are cheap and easy to replace. Make sure you use fuel injection hose and not carb hose.
