gas tank
DAVE PERRY
New Member
I need a new gas tank for TTA I just purchased. Ebay shows all 14 gal tanks. Where should I look for 15 gal tank? Thanks for your help.
Rockauto.com has the 15gal. one for $138.79 and the part# is GM27B.
It is also listed as the same for the 91 and 92 models.
Lock ring included and noted with pan in tank.
I think someone on the forum got one of these before the TTA reunion last July.
Rock Auto [specta] tank fill neck did not line up put in used tank nite before reunion . Specta says tank lines up fine [ have new no good tank]Good luck know of no other new tanks
If you do have to get a used one, make sure its rust free and from a later 91 or a 92, V6-V8 are all the same in those years and have the plastic baffle.
