I recently purchased TTA#545. I had an issue with a vacuum leak in the dash at the AC control which I have resolved.
The car fails the high speed (2500 rpm in neutral) CO test in my state inspection process. I've been told to pour two to three quarts of "clear" rubbing alcohol into the gas tank. The problem is that my local pharmacy has two types of "clear" rubbing alcohol, ethyl and isopropyl. Which is the correct, and/or best type to use?
My second question is in reference to the correct position of the factory aluminum wheels on the car. Which offset, wide or narrow, goes on the front and which goes on the rear?
Thanks for your help!
