How much boost
At least 25PSI, maybe 30PSI.
Do you have the boost? :wink:
Knock,knocki'n on heaven's door....
Methanol or ethanol is the trick...... just step up on the chip to heavy drag racing..... 0X
OK? You follow?
ps
I appreciate the comments. The only fuel i can buy locally over 91 octane is Sunoco 104 Unleaded in 55 gallon drums.
I dont want to drag race the car,,,,just a little more boost :D
I am thinking of having Eric Marshall burn me a chip for about 19-20 lbs is all. I didnt want to overboost the stock wastegate and screw something up :shocked!:
Posted Mon Mar 21, 2005 4:41 pm:
Do you think I will notice much performance gaines from the stock 16.5 lbs versus' say 20 lbs. May not even be worth my time to burn a new chip since I am not going to mod the car other than an open air KN set up.
What do you think??
If you what more boost get an adjustable boost pressure gauge. But remember when you turn the boost up you must have more octain or alky injection. The first thing you need is some type of scan tool to monitor your o2 and your knock or you will be replacing some things that you do not wish to. :lol:
