" don't taze me bro"...I love that under you user name!
Anyway, back to the issue at hand.I was feelin' the same way about the gas issue. He put 200 miles on it in the last 14 months and he said he was using 91 octane. Soooo...I did buy some octane boost and if the weather holds out here I'll go and put 50 miles on it with my scan tool in the next few days.
About my scan tool...It's an older, real time data stream scanner that I bought back in 1992 from the Snap-on dude. It was a trade in and at the time it fit my needs for use on my then '86 2+2 aerocoupe. I don't recall the brand off hand )(MPSI 9000 maybe?)but it plugs into the ALDL and cig lighter. I input the vitals and it shakes hands with ECM and displays real time data such as error codes,O2 readings,TPS,BLM,Integrator yada-yada. Now, I don't know what a scan master is that you all are talking about other than a picture of one I saw mounted under someone's dash. If it does something different than my tool than I suppose I should be looking for that to buy as well.
I did plug it in this morning to see if there were any error codes(none) and I just briefly watched the O2 and knock counts(21) and see where the integrator/BLM were (132,I think?). This was all after it had gone into closed loop.
I need to check it when it's cold as it has unstable idle on start up. Also it doesn't start right up like my TPI car does, it takes 1 or 2 seconds of cranking to fire up. I was told it has a bulldog chip(whatever that one is) and I have the stock prom in the box of stuff he gave me.
Stuff that I know has been done to it; hot wire kit for the fuel pump,aftermarket fuel pump, adjustable fuel pressure regulator and an adjustable wastegate. B& M shift kit. Stuff I've been told was done; looser than stock torque conertor, new stainless steel valves and HD timing chain and gears,HD valve springs and a 3.42 gearset. The owner before this one tried his hand at racing and had 50lb injectors and a more radical chip burned for it and that is why,I'm told, the valve springs and head work were done. Now the next owner couldn't get it to pass IL emissions so back in went the 42lb injectors and the less radical chip and now that's where it sits as I own it.
Thoughts???
