the scanmaster updates so painfully slowly, i dont always want to keep on it while the casper gauge is showing knock.
I'm making the assumption you have the caspers in a pillar pod? If so, train yourself to just keep it in your peripheral vision in realtion to what colors are lit. I don't even notice green L.E.D.s anymore. Right now the scanmaster is your friend.
that remind me of another important question... the casper gauge will stay illuminated at the highest amount of knock detected for a few seconds.
Yes, and I'm not sure what msec or seconds it resets. Maybe a reset after 1.5 seconds, but I know it seems like an eternity.
if you go WOT and downshift, resulting in brief transitional knock, but still enough to max out the casper gauge, how are you supposed to know if youre knocking for those few seconds its not giving you a current readout afterwards?
You don't and that's the problem with knock alert(s). It's just a slap in the face milliseconds before the ECM starts to react.
you cant necessarily rely on the scanmaster,its updating less than once a second and a lot can go wrong in that time if you have real knock.
Yes... you can rely on it. It maybe slow at 2 refresh screens every 1.5 seconds (I think) compared to the TT 6.0 w/ WB but it's better at diagnosing knock than the caspers gauge.
What I'm saying is you know it's detonating, you don't need to be watching the light show anymore,watch the KR numbers and at what O2 values on the scanmaster as it happens at. Your boost is low and your fueling is 800+,right ? The scanmaster will record the highest KR when the engine is in PE mode(power enrichment) look at the scanmaster instructions and get familiar with that function. Also I would isolate when this happens. Above 45mph?, at the 4-3 downshift? under full boost 4th gear and no downshift? under hard launch? before the alky sprays? will it show KR in park when you stab the pedal a couple times?
Then decide if it's real or false or transitional or burst knock based on when it happens. Test again and again and see if the numbers just show up high or ascend like 2.0-2.9-4.6 etc. or is it 19.9 right off the bat.
There is something that I'm still studying up on and that's "rich knock". not a whole lot written about it but it appears that too rich will cause detonation too. My tune is fat at 800 at 18lbs boost and the leaner I make it the less KR I see on the 3-4 shift, so there must be something to it. I'm just to much of a pussy to go down to 770.:whistle:
Don't get discouraged you may be just chasing a fuel pressure problem or a banging tailpipe or loose motor mount.
Maybe for experimentation you should turn the boost down to 10lbs.The try a few runs.
