How fast do you want to go?
Stock mounts can be had just about anywhere for cheap.
But H& R parts and stuff has poly TTA mounts but aren't cheap...but high quality never is cheap.
But loosing the tie down anchor almost justifies them.
Alright Internet racer Joe, tell me how the poly mounts feel in a TTA.
Talon isn't a TTA. our gn has poly mounts EVERYWHERE without an issue. So you're not comparing apples to apples.
Do I have a problem? Not really except the strap is f^cking ugly! It's a bandaids.
Rock Auto, Advance Auto... has the correct mounts. ANCHOR Part # 2627. You will need two right front mounts!
Ordered locally when I did my mounts. Actually ordered 6 mounts.lol I picked out the best 2 at the counter and just purchased them. Kinda like picking through pressure treated wood boards at 84 Lumber yard. I pick the ones I like. Hope this makes sense.
Joe
Joe
Jas0n
You can't tell me with solid mounts that there will be no noticeable vibration at low speeds.
FYI, if you had the strap in the RIGHT place, you would barely notice it.
:cheekiss:
Rock auto has the anchor #2627 for $6.95
Advance auto has them for $19.95 in stock locally.
So for a little over $40 I can see before I buy, or for $6.95 each I can order a few of them and pick the best 2 to use.
Subscribed. Is the tie down strap necessary after poly mounts? They are claiming upwards of 1000hp rating.
