TURBO T/A
Car runs great most of the time but sometimes cuts out. Does not really have to be under a load, just normal driving. Also, if you get in the gas around 3000 rpms and 10 psi boost it acts like you hit a rev limit and bucks. Has new f/p, hot wire, green tops, tt chip. Previous owner did a/c delco coil pack, module, and possible a cam sensor within the past 500 miles.Also tried a known good MAF off a running T-type and a new (reman) ECM. Engine temp does not seem to matter, outside temp maybe. Thanks for the help.
