New Garage
ev2aar-thanks for the info. I have a couple questions for you about the radiant floor heat. How thick is your insulation under the tubes? What do you use for a heat source? We have blue prints drawn up for the location of the 2 post lift and there will be no tubes there. The 4 post lift will be used mainly for storage, but at first will use it for some repair work. That is untill we can get the 2 post-will have to wait a while-until the budget allows. Is your building insulated? We plan on insulating and doing metal in the inside as well.
No problem kymme,here we go:
1/4'' bubble wrap insulation right on the graded ground(provided the insulation and vapor barrier).
4' x 8' sheets of 6''x6'' 10 ga wire screen tied together right on top of the bubble wrap.
1/2'' pex tubing tied and run 1' on center(note the 6''x6'' screen)made it easy,go down one row,180 back skipping one makes them 1' on center.
Loops to be no more than 250' long,I ended up with 5.So making about 1,250 feet of tubing I ran.
Electrical box mounted in floor,cover to be at finished surface of concrete,conduit run back into basement where the control panel.This is for the floor slab sensing bulb for the T-stat.
My heated area of garage is 30x44,I have living space above it.Walls are wood framed 2''x6'',so thats R-19 in the walls,I put R-38 in the ceiling,my garage doors are R-16 rated.Garage has no windows.
My heat source is a NG high effeciency MODULATING boiler that can ramp between 26k BTU's and as high as 155k BTU's.The calculated heat loss for my application was 18k BTU's @ 55 degree slab temp,with 0 degree outside temp.So,I did not want a straight up 125k BTU boiler,to,when it calls,ask only for 18k.NTM,my boiler is serving Hydro-air units around my house.
I ended up running the garage temp @ 65 degrees all winter long,thats 10 more than projected,even on the coldest of days,when it calls for heat,would maybe run for 5-6 minutes to satisfy and then be off for as long 2-3 hours !!!!Very,very effecient.Best thing ever to do for garage heat,bar none !!!!Best environment for the cars.
Now,off the 30x44 garage is a 24x24 garage workshop,that I just finished this year,no heat in there yet,existing slab,so could'nt put in radiant unless I chopped up the floor.The radiant slab was tranferring heat back into that unheated garage keeping it at around 50-55 !!!!Which is insulated and sheetrocked also and has R38 in the ceiling as well.
I'll try and post a pic of the panel I made for the floor system.
Let me elaborate one thing for you,I am in HVAC,and air/water balancing,try and keep your loops,however many you might have within 10% length of eachother,IE... if you end up with three loops....210 feet,185,237 feet,NOT a 50' loop,290'and a 150',they would require balancing and will be tricky for you to get correct.Do the math when laying out the tubing !!! LOOPS NO LONGER THAN 250 FEET !!!!
Its actually rather easy to figure out,take your inside dimensions of the concrete footings in sq.ft.,mine was around the 1,250,so being run 1' on center = your sq.ft,so 1,250, 5 loops @ 250' each.You can't nail it perfectly so do the best you can to keep them as close as poss,again,no more than 10% diff,which equated for me as 25' up or down.
Also,if you can keep them shorter per your situation,like 200' loops,even better.
Forgot to add....the water temp I am sending thru the floor is only 80-85 degree water,there's your other part of effeciency.
Anything I can help you with,if I can answer for you,be glad to do so.
Built a new shop last year. Foundation is basically slab on rock as my property is on river front where the levels are old " beach levels" from the river, so the shale/limestone is about 12- 18" below grade just about anywhere you drop a shovel. Heat will be Propane/Furnace. The garage had to fit in my laneway which curves, this is the reason for the L shaped garage. 24' X 36".
This is a pictures from five (5) years ago. Three Lifts.....Two Standard Size - Backyard Buddy....One Extended Size - Backyard Buddy. Take a trip to the Backyard Buddy factory in Warren, Ohio. Compare the American Contruction, welds etc.; not to mention the sleeved design (ultimate safety). Everything has worked very well, including the sliding hydraulic jack tray and lift moving system. Good luck with your build.
Now that's a mancave ! :worthy:
Thanks for posting the pictures. The Backyard Buddy factory is about an hr or so away. Hoping to get there soon for a tour and sales pitch. Your restroom is very similar to what I have in mind, just something small and purposeful. The actual construction that is going on is very active and I like to be here watching the progress and making sure it is going well. Told the builder from the get go, that we are very picky people and except perfection. The builder advertises his services and "premier"and "gold" quality, so expectations are high.
Also thanks to everyone else for their input and suggestions.
While not near as nice as most, it gets the job done. Heated floor and A/C along with a bathroom/autograph memorabilia room with a attic storage area that I can fit 3rdgen hoods into. Its still not "finished" but I'll get there. My friends and I have built the whole thing..
You guys are making me want to sell my house and just move into a really nice mancave. Damn you all! lol I am fortunate enough to have my 26x26 garage and someday will finish it with insulation and drywall and a lift finally once I find that money tree in the back yard. I think it died or something. I did look at the Rotary lifts and the price and construction for the Direct lifts are plenty for what I am using it for.
TTOP350-Your garage is very nice. Cars look good in there. LMFAO on the refrigerator you have. We have one we have been dragging around with us for about 30 yrs. It wont die! Hubby can't part with it, it has a keg tap on the side and our lives together are pasted all over it. Havent decided yet if it will end up in the new garage.
Kymme, thats kinda the same story with my fridge! It has a keg in it with a coke and beer tapper on the front of it.
It was in my parents basement for as long as I can remember and when they got a new one I grabbed this one up.
I figured that if/when it finally dies I'm going to take the door skins off and mount them on my grarage bathroom door!
I would love to see a pic. of this garage full of cars........
KID
I went to Rich's house today to check out his lift's again and there is no doubt what lift i will buy, only problem is i called Backyard Buddy and they are back ordered 8-week's. I got a price on a 7k-lb extended size, $4895+ $450 shipping. They also have a easy-access jack's that are very nice for $599+ sh, works great if you don't have room for a lift, btw that's what i love about these lift's is you can move them around! they do not bolt to the floor and you can move it with a car on it... cool huh?
Yeah they told me the same thing, about 6-8 wks backordered. Hell for $450 shipping you ought to just come up and pick it and make a weekend of it!! You could stop by and visit and see the new garage!
Sound's like fun but the thought of driving on Ohio road's don't :teehee: but maybe someday, have they poured the slab yet? look's like that's about all that is left... the way mine is going it may Oct. before it's done.
Pictures ... we love pictures :bounce:
Sorry Jan, i got there about 12:30pm and within 10 min. of opening the garage door's it felt like 110 deg., i got one blurry pic of the lift, it was just too hot to hang around long but i'm going back when he has time to take them all out and it's not the hottest time of the day.
Yeah, Ohio roads suck, they keep getting worse, salt in winter + no funds makes for a bad combo.
Nothing to report this week-decided to go with thicker insulation (3") for the radiant floor heat and of course its a special order item, so puts us back about 2 weeks. After the slab is done then its garage doors, spouting and the interior work on the utility area/man cave. So its gonna be awhile:(.
If you think Ohio roads are bad, try driving in Ontario ! :disgust: Very little attention gets paid to roads & infastructure in these parts until it's already 10 years past the point of falling apart. Not good roads to experience WS6/1LE on for sure ! :thumbdwn:
After a several week delay waiting on some special order items, we are back in business. Insulation and heating tubes installed. Floor will be poured 1st of next week.!!
Rectangular area is for 2 post lift, concrete will be around 10 inches there, the rest will be be 5 inches.
