yup bad turbo sounds like. Or going bad at least. Your intercooler is most likely filled with oil as well! Take the turbo off send it out to Limit Engineering or order the kit and rebuild the turbo your self if your daring. But pull the intercooler and flush it out with some gas.
This is an industrial Viton sealed check valve that will not leak under boost and should last forever. Unlike stock steel PCV valves that leak under boost this Billet brass valve features Viton positive action seals that do not leak under boosted conditions. When the stock PCV leaks it causes pressure to build in the crank case causing oil leaks everywhere. This simply replaces your stock PCV for a trouble, maintenance free PCV. On the shelf now.
Also, tell us more about the car. Miles, mods, power, how you drive it, ect.
The car is stock had heads ported&polished havent drove in bout 10yrs dontt race it but iget on it sometimes just got it back out in spring only has 27317 mi on it bought it with 4000 on it intercooler has 0582 is that my build# vin# is g5w2178kl241300
