TTA984
Gold Member
It has been leaking oil thru center acorn nut-washer on driver side valve cover. At 15 or 20 lbs of boost is when it comes thru a little.
It did not take a rocket engineer to figure this one out.
I removed the acorn nut and the washer, and replaced with NOS nut and washer.
As noted in the pic. the Nos washer is much thicker than the one that was on the car, this causing the acorn nut to not tighten up. It was loose with the old washer even when torqued properly at 13ft. lbs.
After installing the Nos nut and washer it is tight now with no leaks.
The Nos one is the left one in the pic. Much thicker than the other one.
All the rest of the valve cover nuts are tight on the car, so this is the only one that was like that.:cheers:
