Pulley & Hose questions
TTAGUY
Ok putting everything back together I decided to clean out the IC, and fix up the IC air shroud. Also with the car came this extra water pump pulley and belt. Just wondering is this the stock pulley and on the car is an aftermarket? Or vice versa? Also can some please tell me what they think previous owners were trying to do with these hoses? I'm sure tranny cooler.
Again thanks for any help,
Marcel
Marcel, the water pump pulley on the car seems to be the stock one ... you got the part number stamped in it so you can look that up or post it here and I can look it up for you however as far as I can tell the one on the car is stock ... then compare that one to the spare one you have.
The hoses you have where done for a transmission oil cooler infront of the radiator ... many of us have the same or similar setup ... if you look at the video I posted the other day when using the handheld camera starting to show the battery next you will see my setup using hardlines all the way up front and the front cooler is in serie with the stock cooler in the radiator.
Thanks jan, I'll look up the part #'s on both pulley, wonder why he had 2 of them if their the same? Found the tranny cooler I need to move it and make sure it stays in place. Paid close attention to your video, seen the set up yours looks professional, this is rigged, lol.
Thanks marcel
