Figured today would be a good day to correctly align the rear hatch as mine has the typical for firebirds one sided overhanging gap. I removed the hatch struts then loosened the hatch to body bolts. Once I closed the hatch I was able to perfectly adjust the hatch. I tightened everything then double checked the gaps...all perfect...until I reconnect the hatch struts. It moved the right side eventhough I tightend the bolts pretty good. I repeated the above steps except this time I tightend a bit more...and on the last bolt....POW! I broke the bolt!
Does anyone here have a rear hatch hinge lying around? I'm dreading removing the entire hatch from the car!!
Help!!! How did folks on the forum fix the alignment problem?
