Rear Spoiler Mounting
JSTTA
I tried to find out in old threads but no luck, I have a fiberglass spoiler, it only has clips on the front. where can i get the original mounting clips for the spoiler that mount on the glass area? My car does not have them on it. Thanks
You gotta change the display options to 100 days or more way down at the bottom of the page to dig up old posts. Took me awhile to figure that out. Anyway here it is and it worked well for me.
http://www.turbotransam.com/forums/showthread.php?t=2273
The OEM clips probably aren't to be found and the new fiberglass spoiler is not molded to accept them any ways.
Jason's way is the way we all probably mounted our spoilers and it takes some fitting to get it correct.
Thanks for the info, I need the clips that go on the glass moulding so the screws slide in.
they're spot welded onto the glass molding so they should be there when you take it off, if they're not then you'll have to replace that entire molding piece. I don't really see them braking off, and as long as it had the same style spoiler on it before they should be there.
