How do you clean them ttop 350?
Sent from my iPhone using Tapatalk
Oil pressure switch and FP relay. without oil pressure, it won't let the FP relay kick the FP on to send fuel to injectors. Does FP buzz for2 seconds when you turn the key to on?
You may have a bad FP also if no 2 sec buzz
edit: seen replaced FP
I thought the op switch was a just a backup to run the pump if the relay was bad? Thatsbthe way I interpret what Jan described here problem whit fuel pump always on key off ? need help or schematic - Turbo Trans Am Forum
