I bought this car in Oct. and it has been in the shop ever since. It has 20,500 miles on it and only 5,000 put on in the last 8 years. I has a full tune up done on it as well as new injectors and chip. The guy working on it says it still has a rough idle. He has done alot of work on GN's but not much on TTA's. He checked the valves, springs, comp. ratio and can't figure out what is causing the rough idle. He said it sounds like a car does when it has a beefer cam put in. I don't want to pay the extra money for him to keep hunting this ghost (tearing the motor apart to check the cam). I am woundering if anyone knows anything about this (is it a common problem or is it ment to have the throaty rumble and rough idle). Also could it be that the car has not been driven enough and maby just needs to be run. And is the timing gear on the TTA metal or plastic. The guy said he thought GN's used a junk plastic timing gear that wore out causing the car to slightly slip out of timing, also he noticed my timing chain was a little loose. Any insight would be welcome. [/b]
