jarredsoon
Alright TTA 733 is all back together, everything good. My scanmaster numbers all look good. Int is 128 BUT..... BLM is 138 on cold start for 8 sec then 133 at idle and hot idle. ( hot idle being 165-168) I listened to the motor with a tube for a vac leak and heard a hiss at the vacuum block. I replaced the gasket and bolts but no change. I listened more and heard the hiss from the bolt holding the throttle body to the plenum. Is it even possible for a vac leak to leak through bolt threads/ holes?? Its the bolt by the number 2 in the pic. Or is it more likely the tb gasket?? Should I even worry about blm 133?? It concerns me cause my other cars are 128 blm steady. Here are some pics...
