gatorlance
So I got #689 back together this weekend. Changed oil with some Mobil 1, Napa 1086 filter, changed coolant and it runs great. Can't wait to put the TT chip in next weekend to see how much smoother it will run with a bit less timing.
After it warmed up, I made a short run at WOT and did notice that the boost pretty much hovers around 10psi and then will make a slow but sure climb to the 16# limit. Stock turbo, IC and DP on the car.
I'm thinking this may be a leaky wastegate, but can't tell. I did verify that the Y-fitting is connected correctly per the old diagram - with the straight-through going to the turbo.
Any thoughts? or should I just go get a new wastegate actuator? Any suggestions on where to get one for a TTA?
Thanks all.
Regards,
Lance
Thanks all.
Regards,
Lance
