Buckeyetroop
I just had the Jim Dunn DP installed and the guy doing my work says I need to replace the plug wires with angled boot wires to get them off the DP. Any thoughts. What wires are you guys with this DP using? Thanks
I put 135 degree boots (so just replaced the rubber boot and bent the metal connector slightly and works fine) on the stock wires ... front two on the passanger side then used the heatshield "socks" you can get (this type http://www.heatshieldproducts.com/insul-boot.php) on those two ...
You could do this "mod" to any plug wires
