Update on my starting problem. I have had my car sitting outside for quite a while and lately when I went to start it, there was no response from turning the key - no noise from the starter. I went under the car and shorted the 12v main cable at the starter to the other electrical pin on the solenoid and it immediately activated and the starter began to turn, so the problem is not at the starter. It must be somewhere between the ignition switch and the solenoid, where it is not sending 12v down to the solenoid when I turn the key to start. I assume I have to get access to the wiring from the starter switch, probably removing the switch from the steering column, and I haven't found any videos showing how to do that for the '89 TTA. Can anyone help me access a video, if any, showing this, or is there any other way to check the operation of the starter system without removing the switch?
I have a wiring diagram of the fuse box wiring system that shows the ignition switch connections to the starter/solenoid. There is a FUSIBLE LINK in the line, and a PASS-KEY DECODER MODULE connection that must work, and the GEAR SELECTION SWITCH that must operate, so a number of places where the problem could be. I assume if the problem is the gear selection switch I would have to open the shifter console to get access to the gear selector switch. In the meantime I will start searching for the fusible link and pass-key decoder module to see if they are working.
Any help in locating these, or any other steps I could take, would be greatly appreciated.
