Over 20% stiffer from the 980 to 981. Just simply
not needed for 53000 rpms.
Let's agree to disagree.![]()
Just make sure you use a bottle of zddp or the comp cam zinc additive at every oil change.
Once those 980s are broken in I bet they near -5/-10 less than the advertised pressure at the installed height.
Since I'll have the rockers off should I change to roller rockers and bigger ratio get alittle more out of it?
Kyle
Maybe bigger ratio on exhaust side only:idea5:
WOW 1.7 factory, I guess I'm used to the old small block chevy's
Probably need to do springs before Alky and pump
OK where the best place to get them?
