Subframe connectors Question
1083turbo
Im gonna order some subframe connectors and i was just wondering if there are ones that fit better then others.
I had South Side Machine weld in SFC years ago. Ordered them from Summit I believe. The biggest issue is making sure they clear the downpipe and exhaust on the passenger side. I actually brought the car to a shop that makes their own SFCs first thinking they could modify the SFCs if needed. They wanted to modify the car instead so I said no thanks. :wall:
Thanks guys, I placed my order today and went with the BMR. Adding some power soon so figured sooner then later i would need them.ttarider
I'm going with the Spohn SFC'S. Just to keep everything the same. I already have the Pro-Series torque arm, and Panhard bar. I think any if them installed properly will be fine.
My torque arm is spohn and my transmission is a 200-4r and my drive shaft doesn't fit through the loop. I had to grind the loop to let the driveshaft (4") clear. That's my only complaint. I have all the spohn rear stuff.
I have a 3.5" driveshaft. My loop was pretty tight too. I actually cut it off, and I'm making it bigger. I wish Spohn made it wider to start with. Oh well. Their stuff is still really nice!
